ok to weld k member?
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
The tab where the a arm mounts to speparated from the k member (only the one side) as a result from a curb accident (25 mph) Can I just have it welded and be able to drive it safely and have it hold under hard cornering or should I just replace the whole thing. Yes I know it would be best just to replace it but I'd like to be back on the road as soon as possible. The actual K member doesnt look bent or twisted, it appears the a arm, spindle, and wheel took the brunt of the impact.
the blue in the pic is where it ripped
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if nothing is bent or compromised, i dont see why a GOOD weld job won't fix it, but a new one is not available unless you get a tubular one, which is an idea, or hit the junkyard.
Time wise its not gonna matter if you replace it or weld it, either way a K-member needs to come out and another one goes back in. The process of doing that is what takes all the time. I would source a used one from the junkyard if it were me, like I said in the other thread as long as its not rusted or bent then its good (not a wear item). If you do have it welded make sure the person doing it knows what they are doing.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
this would be one of thoes cases where i would just get a new one... and by new, i mean one from another car.... it should be free or really cheap.. if its not, then look around somemore.
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
Structurally, it'll be perfectly fine to weld it, it the individual knows what they are doing. But expense wise, if you don't have a welder at your disposal, and will need to take it to a shop and pay for the repair, it may just be cheaper to pick one up at a junkyard.
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
