What size wheel?
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
What size wheel?
I want to get new wheels for my 1984 trans am but I dont know what back spacing I will need? I want to get some 16x8" wheels and I plan on running 255-60-16's all the way around...what backspacing will I need for the front and back wheels? I am running stock disk-drum brakes by the way.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
255/60 might be a little tall for the front,
I have a 245/50/16 on my 86ta, looks great, i guess a 4.5 inch back spacing, but you should get other opinions.
Car: 1984 Trans Am
Yeah your right I ment a 245/50-16 thats what they used on the GTA all the way around...I am looking at some GTA wheels but they are so expensive and I can get aftermarket wheels for alot less but I dont now how much back spacing is needed for the front and rear? On the GTA wheels there is a difference between the front and back wheel if you use the back wheels on the front they will rub.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea the 91-92 were different, like the camaros, I use the same all the way arround on my 86 and it is fine, I enjoy the ability to rotate my tires and rims ,they make a 275/45/16 @ www.tirerack.com that would be sick for the rear, I am thinking of buying a set of 2.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
As a 245 50 16 is 25.7" tall and a 255 50 16 is 26.1" tall, either will be fine and won't cause any speedo issues. So the 25 is not too tall. I would recommend a 4.5" backspace. You won't have any rub issues with either wheel size with this backspace.
Enjoy.........
Enjoy.........
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
