quick tire question
Old Jan 2, 2007 | 06:47 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
quick tire question
I've gone through a lot of searches, and all I'm looking to know is can you run 255/50/16's on all 4 corners, without issues
Old Jan 2, 2007 | 07:07 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have a 245/50/16 all the way arround without issues, once had a 265/50/16 omn the back, it looked great but they arent cheap.I know a 255 isnt that much wider, you would be fine.
Old Jan 3, 2007 | 03:00 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
What issues do you think you will have? The tread width of a 255 is only 0.4" wider than a 245. This means that the 255 will be 0.2" wider on the insdie of the rim (toward the inner wheel well) and 0.2" wider on the outside or the part of the rim that you see. SO there should no be any rubbing issues if you are using a stock rim or a reasonable offset or backspace.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
