Where can i get some Lowering springs in Toronto for a V6 82 S/E ???
Old Jan 7, 2007 | 11:19 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hi ! i broke a spring on my 82 s/e and i have a friend that can send me
one,but i want to install a set of lowering springs and he asked me for some
address where he can get a kit
is there anything more i will need to install them ?
Where can i get a set and which ones can you recommend me ?
thank you guys !
Old Jan 8, 2007 | 05:23 PM
Calderone's Avatar
Car: 87 Vette
any help ?
thanx
Old Jan 9, 2007 | 10:53 PM
Calderone's Avatar
Car: 87 Vette
c'mon guys !
Old Jan 10, 2007 | 07:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
He should be able to special order them at a "Parts Source" store, or Canadian tire. He'll probably want to look up the exact part number first, since the staff there are usually a bunch of shaved apes.
I wouldn't recommend lowering springs at all, especially on a V6 car. I don't think there's anything that you need to get, the "kit" should cover it all.
Old Jan 10, 2007 | 09:17 PM
Calderone's Avatar
Car: 87 Vette
why you won't recommend lowering springs ?
Old Jan 10, 2007 | 09:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
They're usually designed for a V8 car (weight), so my first guess is that they won't have the desired effect.
2nd - lowering springs suck. You'll be scraping the bottom end of your car all over the place, you have to drive around like a little old lady so you don't crush the underside of the car. It's not a Bentley, IT'S A CAMARO! Drive it like one! Plus they throw off the suspension characteristics of the car from the factory setup, so it just messes things up. eg, LCA angle.
All it does is make the car look cool. I'd rather use a body kit if that's what you're going for.
Anyway, it's your car, you should be able to get your buddy to grab 'em from those sources, just make sure you give him the correct part #. Last thing you want is to get the wrong ones shipped all the way down to you
Old Jan 11, 2007 | 04:57 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
There are a few speed shops that you can get lowering springs from. Try Karbelt in pickering(905-839-4421), Bolt-on performance in bolton(905-857-3333), Redline performance in scarborough (416-292-5320). All good places to deal with with decent prices.
Old Jan 13, 2007 | 04:20 PM
Calderone's Avatar
Car: 87 Vette
thanx for your replies !!!!
good point Sonix !
Thanx Bill !
Old Jan 13, 2007 | 06:20 PM
Calderone's Avatar
Car: 87 Vette
how much does the kit weight ?
thanx
okfoz
Jul 1, 2024 01:40 PM
Calderone
Canadian Region
Jan 12, 2007 06:47 PM
jcurrieirocz
Oct 6, 2004 07:58 PM
Mike Harvey
Jan 25, 2001 03:51 AM
Mike Harvey
Jan 2, 2001 05:19 AM
