Changing Springs to 82 Camaro From 88 Firebird
Old Jan 10, 2007 | 06:45 PM
Mainky34's Avatar
Hey! Once again, you guys are the most helpful people in the world for my son and I who are trying to "fix up" his 1982 Camaro.
We have an '88 Firebird that originally had a 305 in it.
The Camaro originally had a 2.8l, 6 liter engine in it. Now we have put an 81 Chevy Vette 350 in the Camaro. The front end virtually sits on the ground...the front engine mud flap literally sits approximately 1" from the ground.
I have decided that since the firebird had a V8 in it the springs are probably stronger than the ones in the camaro....am I right?
I have purchased spring compressors to trade the springs from the firebird to the camaro. I have never changed springs on any vehicle before. Does anyone have any advice, hints or tips they would graceously give me before I get started? hehe Like maybe how to get started...lol
Anyway....you guys have been more helpful than anyone on my son's and my Car adventure. Thanks so much for your help and hopefully someday I will be able to help people who need help on this site. I have always been a Ford fan....a Mustang Man...(owned a fantastic 69 coupe), but quickly becoming a CHEVY fan.........love them Camaros!
Old Jan 10, 2007 | 07:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I do dam near 90% of the work myself on my car. I have done springs twice and I consider the spring compressors widow makers. If you know nothing about it, I would severely consider taking it to a shop and having them swap them out for you. You'll know what I mean when you try to get the new ones in and seated correctly.
Old Jan 10, 2007 | 07:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
spring compressors scare me. i have a set and have taken out my springs twice now and i winch everytime i pull the spring out of the car.
Old Jan 10, 2007 | 10:00 PM
formulascott's Avatar
Car: 1990 WS6 FORMULA
Engine: LT-1/LT-4
Transmission: 1995 T-56
Axle/Gears: 1995 3.42 Disk rear
not that hard
put the car in the air with jack stands on the frount sub frame. Useing a jack, put it under the spring perch under the lower control arm put a light amout of pressure on it. Then remove the (2) strut to spindle bolts&nuts, then slowley relive the presure from the jack. The spring should just about fall out. Instal the new spring and reverse prosedure. hope this helps good luck!
Old Jan 11, 2007 | 05:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/susp...ay-change.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
