How to support car to weld SFC's?
Old Jan 15, 2007 | 05:19 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
So, should the car be on it's wheels or is it possible to jack it up then weld them on? A combination of both? I want to be sure it's done right since it will become an welded integral part of the frame...
I have Spohn SFC's.
I just got my JetHot Hooker 2055's installed, so I was gonna make the bottom nice and get the SFC's and the cat back done at the same time...
Thanks,
Rafael.
Old Jan 15, 2007 | 05:44 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Car needs to be sitting like it is in on the ground(suspension compressed). When mine were welded in we had all 4 tires on ramps.
Old Jan 15, 2007 | 07:31 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Roll on lift for uniform support. Anything else and you are wasting your time on a bad installation.
Old Jan 15, 2007 | 10:36 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Jack stands under the axle and under the front a-arms will simulate the car sitting on it's wheels except higher off the floor.
Old Jan 15, 2007 | 04:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
that's how i did mine a few years ago.
Old Jan 15, 2007 | 04:53 PM
The suspension doesn't have to be "loaded", or anything of the kind.
The goal is to make sure the car is STRAIGHT. It's truly a beeotch to remove SFCs that are welded onto a bent car, and are now holding the car bent.
In fact, if your car is like most of these, it probably sags in the middle; and could use the car bent back straight before the SFCs are installed.
If you want a really premium job, take the car to a frame shop, and have them put the car on their jig and hold it STRAIGHT while welding them up.
Or do like I did. I had mine put on using a race car jig, when there wasn't even any suspension there; front or rear. No drive train either. Just a naked chassis.
Old Jan 16, 2007 | 11:09 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
...if your car is like most of these, it probably sags in the middle; and could use the car bent back straight before the SFCs are installed.
Picky, picky, picky... "Sofakingdom" definitely knows his shee-yit, but if you're like most of us "mere mortals", then just supporting the front A-arms & the rear axle (as it is when sitting on the ground) should prove sufficient.
Nothing wrong with going "all-out" though, if you can manage it... Either way, you'll be happy with the way the car feels afterwards.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
