Edelbrock TBI strut tower brace question?
I just purchased one for my 91 RS. I was just eyeballing it up on the car loosely assembled and the brackets didn't seem to sit flat on the strut towers. I didn't drill any holes yet. Anyone have any issues with this brace?Does it just need to be drilled and secured to sit flat on the strut towers? Thanks, Tim
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Maybe you had the brackets reversed?Which way were the oriented?The long side on the bracket faces the fender.This is an edelbrock STB for a TPI on my 84, but the brackets should be the same.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
By flat do you mean the brackets are not fully contacting the strut towers.Are you leaving the bolts loose enough.Also the brackets are left & right handed.Try switching them around.
Car: 91 Camaro Vert RS
Axle/Gears: one wheel wonder
I am having the same problem on My 91 RS Vert. I just got the stb this weekend and the front brackets do not sit on the towers flat. Any help would be great.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Make sure the brackets are positioned with the taller part of the bracket toward the firewall side and the shorter one to the front of the car. This will allow the mounts to sit flush on the towers and have the brace sitting level. You did position the cowl mount UNDERNEATH the cowl lip, right? If not this would keep the tower mounts from sitting flush as well.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
my edelbrock s.t.b.
i picked mine up today at noon . had the same frustrations as both of you . looked at some pics. here . went back and realized that someone on the assembley line had put the decal on the bottom of the brace , the small decal should face the engine , or down . after that all went smooth . remember the bracket on the back of the brace goes under the lip on the fire wall . if your like me you will drop a nut or 2 getting the rear bolts & nuts started . looks to me that the brace would be in the way of dist. and plug wire work . so when mine comes off next time i am going weld nuts on the underside of the rear bracket . should make it easy to remove and re-install . if you weld nuts when you install/re-install use grade 5 or 8 nuts . [ do not use cheap hardware , you will be sorry if you do ] hope this helps . hope you read this before you start drilling holes . lol uncle tom , ret. acft. mech.
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey, can you post some up close shots of how the stb brackets sit on the strut tower and cowl area? I bought one for my 83 Z and I am having the same problems as the original poster. Also did your windshield washer pump get in the way?
