sway bar size
Old Jan 25, 2007 | 12:01 PM
ohyeahjay's Avatar
sway bar size
anyone know the size of the front and rear sway bars on a stock 82 z28
Old Jan 25, 2007 | 11:42 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Take a look at the information in this past thread
https://www.thirdgen.org/techbb2/showthre...threadid=59687
You can also confirm the size by measuring them on your car.
Dave
Old Jan 26, 2007 | 06:18 PM
ohyeahjay's Avatar
my car is in winter storage about an hour away that is why i was asking if anyone knew or not. im buying parts now but if no one knows i'll have to wait tilll i get it out of storage
Old Jan 31, 2007 | 07:14 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
As in Ebmiller's post,that 82CrossFire Z28 posted the link to,your '82 should have a solid 32mm front bar/solid 21mm rear bar.That is what she would have come with from the factory but actually measuring them is the only way to know for sure.My '83 came with the same 32/21 bars as the '82s but since I've had her I've swapped the front to a hollow 36mm bar and added the TDS steering brace.Along with the poly bushings I've noticed much improved steering responce.
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
m00n420
Sep 11, 2015 02:39 PM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
