FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Questions answered.....Sway bar sizes inside!!!!
Old Nov 22, 2001 | 07:25 AM
ebmiller88's Avatar
Hey guys and gals. I have noticed a lot of people asking what size bars they have, and after being under the nose of a salvage yard IROC on Tuesday, I thought I would take some time and clear some questions up. Plus, what else do I have to do while I'm at work on T/G?
I got all this info from my parts and illustration manual. Those things really help a lot, and if you do a lot of part searching, I would get one...it'll save you a lot of time. Also, look into the CD rom version listed on the home page.
FYI, RPO codes are as follows from the decoder:
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
FE1 : SUSPENSION SYSTEM, S0FT RIDE
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
FE3 : SUSPENSION SYSTEM, SPORT
Unable to locate code ZK3 in our database!
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
ZK3 is the export model so if you have one, you know who you are. Part numbers follow the descriptions.
91 F41 FRONT (34 MM) 14094339
91 F41 REAR (21 MM) 10021221
(REAR POSSIBLY FE2 ALSO)
91 FE2 FRONT (36 MM) 14094344
91 FE2 REAR (24 MM) 10035033
90 (NO CODE GIVEN) FRONT (36 MM) 14094344
90 (NO CODE GIVEN) FRONT (34 MM) 14094339
90-91 FE1 FRONT (30 MM) 14047916
90 (NO CODE GIVEN) REAR (24 MM) 10035033
89 FE2 FRONT (36 MM) 14094344
89-91 FE1 REAR (18 MM) 10021220
87-89 FE2,F41 FRONT (34 MM) 14094339
88-90 FE2,F41 REAR (21 MM) 10021221
87-89 EXCEPT FE2,F41 FRONT (30 MM) 14047916
87-88 EXCEPT FE2,F41 REAR (18 MM) 10021220
86 (NO CODE GIVEN) FRONT (27 MM) 14019268
86-87 EXCEPT ZK3/Z28 FRONT (30 MM) 14047916
86 ZK3/Z28 FRONT (34 MM) 14094339
86 EXCEPT ZK3/Z28 REAR (18 MM) 10021220
85 FE2 FRONT (34 MM) 14073013
85-87 FE2 REAR (24 MM) 10035033
85-86 ZK3 REAR (21 MM) 10021221
85-86 Z28 (EXCEPT FE2) REAR (21 MM) 10021221
84-85 ZK3/Z28 FRONT (32 MM) 14047917
84-85 EXCEPT F41, ZK3/Z28 FRONT (27 MM) 14019268
82-83 (EXCEPT Z28,F41) FRONT (27 MM) 14019268
82-83 Z28 FRONT (32 MM) 14047917
82-85 F41 FRONT (30 MM) 14047916
82-84 Z28 REAR (21 MM) 10021221
82-85 F41 REAR (18 MM) 10021220
That ought to do it. Some had no "codes" and I have no idea what the hell that means. So by checking these codes against what is in your car, you should be able to verify what bars you have.
Hope this helps. Happy Thanksgiving to all!!!
Later
Ed Miller
Charlotte, NC
1991 RS, 305 TBI,
bone stock driver;
1988 IROC L98
TPIS Fast Pack, modified MAF, MSD 6A, Dynomax cat-back so far.
"Do you want to race or don't ya? I want to race." Dale Earnhardt
[This message has been edited by ebmiller88 (edited November 22, 2001).]
Old Nov 23, 2001 | 12:07 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I may as well toss a bolt into the fan.
I currently have an 86 IROC-Z.
Its an FE2/Z28 car.
The stock/original rear bar was the 24mm as listed, but the stock/original front bar was 32mm which was not listed.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Nov 23, 2001 | 07:53 AM
ebmiller88's Avatar
Figures....50/50/90 rule...
Old Nov 24, 2001 | 12:01 PM
ebmiller88's Avatar
ttt
Old Jun 28, 2002 | 06:30 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I use my digital calipers and set it to metric mode. I took them with me to the pick-a-part. (2) 34mm front, (1) 36mm front, (1) 24mm rear, (1) 23mm rear bars left for home with me. Lon
Old Jul 2, 2002 | 12:25 PM
ebmiller88's Avatar
Well done!!
BTW Lon, I'm gonna use the 36mm Guldstrand bushings on my front bar until I get a set of your greasable ones.
I also found this interesting. I have called ES twice asking them about 36mm bushings and they have told me "No" both times. When I got my Guldstrand bushings yesterday, they came with a small packet of Formula 5 lube with "Energy Suspension" printed on it in the package.
WTF????????
Maybe Guldstrand has a deal with ES or something.
Ed
Old Jul 2, 2002 | 01:38 PM
lonsal's Avatar
Ed, If you wait about a week on installing the Gulstrand 36mm bushing we can just swap yours for the one that I ship you with the set. The brackets are going out for plating this week. I'm just waiting for my 1/4" bushing to arrive today for my Procunier tapper before I can roll-tap them. I have one Gulstrand 36mm bushing set arriving today for evaluation. I'll likely be using it, since they claim it fits the stock GM brackets, (which I am using). There is a big difference in my cost for the 36mm vs 32mm & 34mm from ES. So that assembly will price a bit higher. Well, back out to the bead blaster I go...Lon
Old Jul 2, 2002 | 04:18 PM
ebmiller88's Avatar
Sure, will do. I can wait a week.
Old Jul 2, 2002 | 09:14 PM
dan84transam's Avatar
Hmm.. I cant seem to find any of those rpo codes u listed on my Service Parts Identification sticker on my car. I have a 1984 Trans am, and it does have sway bars..
Dan
Old Aug 6, 2002 | 12:03 AM
laegion's Avatar
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
yeah i think that those are for chevy only. not pontiac.
Old Sep 9, 2003 | 06:40 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Could someone please explain the performance difference between the solid and hollow versions? Is there any or was this purely to save on weight.... thanks guys
Will
Old Sep 10, 2003 | 11:05 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I would guess the solid would be stiffer than the hollow?
Old Sep 11, 2003 | 02:42 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Yea, you'd think, but from what I've read before the solid front bars a just heavier, little if any perf difference than a hollow bar. I picked up a 36mm solid front bar from PickYour Part, it felt like 20 lbs. Works good though, a noticable improvement over the hollow 34mm that it replaced. I might have to go back after a 36mm hollow to check for any noticable perf difference.
All rear bars are solid. I picked up a 24mm for the rear at the same time.
Old Sep 14, 2003 | 10:54 PM
CaysE's Avatar
Typically, a hollow cylinder is stronger than a solid one. I'm not sure if this applies to torsional stress though, which is mostly what stabilizer bars deal with.
Old Oct 23, 2003 | 10:41 PM
25THRSS's Avatar
Just measured my 92 RS sway bars with the F41 suspension today, and I have the 34mm front and 21mm rear bars.
Old Oct 24, 2003 | 01:54 PM
Jon92TA's Avatar
Yes, the 36 solid bar (Unknown brand) I have is definately Heavier and Stiffer than the 36 hollow I'm trying now. With the solid when I push down on a front fender the front end moves as a unit, no rocking side to side, the front sticks great but feels like the rear wants to come around in a hard turn. I'd like to have a matching rear bar to have a matched set. The factory 36 hollow & 24 solid rear, feel like a good matched set and keep the car 90-95% as flat in turns and has a smoother ride.
Old Apr 14, 2004 | 03:48 PM
Abaddon_fallen1's Avatar
Car: city bus
Engine: turbo diesel
Transmission: auto
Axle/Gears: be damned if I know, it's not mine
Metric to standard
Would you be able to put the size in inches rather than milimeters, I plan to get a 1 1/4" solid front bar and a 1" solid rear bar just wonder how their metric equivalents match up or is there no difference at all between ANSI and metric. Just wondering.
Old Apr 14, 2004 | 04:16 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Re: Metric to standard
http://www.worldwidemetric.com/metcal.htm
36mm=1.42in
So I guess the 1.25in bar is pretty much the same as the solid 34.
Old Apr 14, 2004 | 06:37 PM
ebmiller88's Avatar
1 inch= 25.4mm= 2.54cm
Ed
Old Apr 15, 2004 | 11:55 AM
Car: city bus
Transmission: auto
Swaybar size
Thanks for the help with the measurements. My question now being, are there any companies that make large diameter swaybars, maybe up to 38mm or 39mm (40mm?). I belive that a 38mm front and a 34/36mm rear would be a good setup. Could any one list pros and cons?
Old Apr 15, 2004 | 12:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Swaybar size
http://www.spohn.net/category.cfm?categoryid=1051
when i converted to metric i got 33.34mm front and 25.4mm rear..
but they are solid chrome moly bars, so i donno how much that effects it....
Old Apr 17, 2004 | 12:00 PM
bigals87z28's Avatar
Car: Check The Sig
i picked up a set of hollow 36 and a solid 24 for under 100 on ebay. Now I need to know where I can get some greese for the poly links.
Old Apr 17, 2004 | 12:31 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Spohn sells the synthetic greese, I think M1 full synthetic will work too.
Old Apr 21, 2004 | 10:13 AM
Steve89GTA's Avatar
ok, so I've got an 89 GTA...am I safe to assume it has the 36mm hollow front and 24mm solid rear? I want to order new bushings but am not 100% on the sizes. Spohn does not sell a regular 36mm front...only the greasable ones...hmm.
Old Apr 21, 2004 | 10:26 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Use an ajustable wrench to get the diameter, and measure.
Old May 22, 2004 | 02:07 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
ok, so look for a 36 and a 24. got it. but do i want solid or hollow front? is there anyway to tell solid or hollow besides taking it off and weighing it? or am i just haveing a brain fart and should just use common sense?
john
Old May 22, 2004 | 05:43 AM
ebmiller88's Avatar
The hollow bars will have 2 small drain holes, one at each end close to where the bar ends are crimped, look for those.
Ed
Old May 22, 2004 | 09:15 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i got the greasable front bushing from spohn, and they say 1 3/8 on them and dont fit really good i got one to seat (i dunno if that proper terminology) but the other one i cant, so the gap in the bushing is much bigger on one side. im going to go mess with it now and see if i can get anywhere
Old May 23, 2004 | 10:31 AM
Car: 89 RS
Ed
thank you kindly sir, junk yard, here i come.
john
Old May 24, 2004 | 08:57 AM
Car: 89 RS
couldn't find any 36 mm at the junk yark, i did find a wonder bar (its now mine). I did also find a 34mm solid front bar, i currently have a 30mm, would i notice a big diff with a 34 or should i hold out for a 36? what are you alls thoughts?
john
Old Nov 7, 2006 | 02:47 PM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
I got a '87 Iroc-z with the FE2 option. So, I got 34 up front and 24 out back? So, should the front be hollow or solid? How was that determined from the factory?
What are the biggest ones offered from the factory, front and back? 36 & 24?
TIA, Nick.
Old Dec 22, 2006 | 09:07 AM
SR-71's Avatar
Car: '88 Formula
Engine: 406, CF heads, Comp 212/218, Rhoads
Transmission: WC T5, 0.61 option
Axle/Gears: 10-bolt 3.08, re-ground Auburn Posi
I just read through this whole thread, Nick. And I see there is a general misconception about solid vs. hollow.
Solid or hollow means nothing. Two bars, same diameter, one hollow and one solid. The hollow may be stiffer. The solid may be stiffer. Or they can be the same. The only consistent difference between them is that hollow is lighter.
Just like springs. The stiffness of the bar comes not only from the construction and diameter, but also from the formulation of the metal and how it's been tempered.
Unfortunately, all you can do is try different setups 'til you find the one you like. Or go to an aftermarket maker who can tell you exactly what you're buying.
Old Jul 2, 2007 | 11:10 PM
HaIrLeSsHoBo's Avatar
Car: 86' Trans-Am (wrecked)
Engine: none currently
Transmission: Borg-Warner T-5
Axle/Gears: 2.86:1 w/ one broken axle
Re: Questions answered.....Sway bar sizes inside!!!!
dumb question i know, but i don't know much about sway bars and suspension.. does a stiffer/larger diameter sway bar mean tighter handling? I measured my current sway bars on my 86' TA and the front is a 36mm hollow and the rear is a 24mm solid. Is this the "ideal" factory setup? How much would replacing these missing end link bushings (is that what they are called) on the rear help.
Attached Thumbnails Questions answered.....Sway bar sizes inside!!!!-mvc-508f.jpg
Old Nov 8, 2007 | 03:42 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
My car has got no stickers for codes anywhere. I was thinking id just need the biggest ones with it being a GTA but after seeing they are different for Camaro's im not so sure now.
my car is an 87 GTA, anyone know the front and rear sizes off the top of their head ?
Old Oct 30, 2011 | 06:54 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
So I looked up the sizes of the sway bars for what my Iroc should have however when I measured it I came up with 32 mm? Did I measure it wrong or is it really 32 mm?
Old Oct 31, 2011 | 12:39 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
I am not so sure how accurate or complete the information is regarding sway bar sizes since the original post date is November 2001. That's ten year old info. For example, I have a 1986 Z with a factory rear sway bar size of 23 mm measured with a digital caliper gauge. The front sway bar measures 34 mm. The OP shows no 23 mm rear sway bar in his list for 1986. I would investigate a little further.
Old Jan 16, 2012 | 02:57 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
How much of a problem am I going to encounter if using 33 mm vice 34 mm bushings?
Replacing front sway bar bushings (87-89 FE2,F41 FRONT (34 MM) 14094339)
Thanks!
After searching web... and searching... was able to find correct size for some Energy Suspension parts
Last edited by scooter500; Jan 16, 2012 at 04:11 PM. Reason: finally found right part
Old Feb 17, 2012 | 09:09 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
34mm Solid front (85 Trans Am )
36mm hollow front (89+ several models )
25mm solid rear (85 Trans Am )
Old May 15, 2012 | 10:56 AM
rafterrat_2005's Avatar
Car: 1988 T/A Hatchback
Engine: 5.0 TBI soon to be carbed
Axle/Gears: 10 bolt 3:73 not sure on the gearin
I have an '88 T/A T-Top that has the performance suspension (plate on the passenger side dash under the map holder(?) what does this consist of and sizes if possible like swaybar and so-forth? Was this standard?
Old Dec 17, 2014 | 09:27 AM
BADASS4504's Avatar
what sise would I need for a 1982 recaro trans am front and back sway bar????
Old Dec 23, 2014 | 06:04 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Just means WS6 suspension. Had it on my 88 T/A. 36 front bar, 24 rear bar and I believe stiffer coil springs and better shocks/struts
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
