question
Old Jan 27, 2007 | 08:38 AM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
question
looking at the rearend of a vehicle, viewing the rear tires. you see 3 tread groves on 1 side and 2 on the other. so it looks like the bumber is offset to one side alittle. whats this a sign of? could it be supension related from a car setting for along time on a slight slope? or unibody dmg?
Old Jan 27, 2007 | 09:18 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
is the car Lowered/Raised from the factory height? If so the panhard bar is at a different angle from stock and hence the rerend will get pulled or pushed a bit either way. Lowered/sagging it will go to the Drivers side and raised it will go to the pass side.
Its also possible that if you have not replaced the PHB bushings that they are worn and not holding the rear in place as well as they should.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
