Tourqe arms, Sub Frame Connectors.. Best??
Old Jan 30, 2007 | 06:18 PM
ttopformula88's Avatar
Car: 1988 Formula
Axle/Gears: 3.73 Posi
Alright here goes.. Any suggestions?
I have an '88 formula, 305, t-5. Was looking one day to upgrade to a 383 stroker running about 400 hp. Lowered.. about 1 in. 3 inch exhaust kit.. Ground clearance is a bit of an issue.
What is the best tourqe arm and subframe connectors for my application?
Old Jan 31, 2007 | 05:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There is no definitive answer to "best." I'd suggest a search.
JamesC
Old Jan 31, 2007 | 06:56 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
there are many post about this subject do a search you will get all the answers your looking for. Thanks Daniel
Old Jan 31, 2007 | 07:18 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i have UMI subframe connectors installed, and they are pretty beefed, they made my ride alot better.
id also like to know about a torque arm though.
Old Jan 31, 2007 | 07:32 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I just installed the comp engineering SBCs on my RS, rides stiff, feel every bump, when i jack the front right up off the ground the left side comes up right along with it, makes it really stiff, welded them in, they are the design for the lung tube headers, i am pleased with them, but i too am still indecisive on buying a new torque arm.
Old Jan 31, 2007 | 08:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I use Spohn Torque arm...adjustable with the front driveshaft loop. fit was excellent. works great too.
i hear spohn subframes are great too, as they have a 3rd set piece that triangulates the connector rails to the floor pan. extra stiffness.
seen pics on this sight about the Alston's SFC's and they worked great too. lift one side off the ground, the other is quickly to follow. very stiff car
cant go wrong either way
Old Jan 31, 2007 | 10:16 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I am in the process of welding 2 torque arms together, and using Energy suspension bushings....I will let everyone know how this goes....Has anyone else tried this.??????????
....I love aftermarket, and it is in the future, but for now, I have spent so much..I am going to box my LCA's and try this trick with the torque arm....Tom
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
