Bolt Pattern Question
Old Jan 16, 2007 | 05:18 PM
Whoodoo's Avatar
Im looking to get some Aero Series 59 Wheels. The only problem is, the bolt pattern is 5 on 5. Correct me if I'm wrong, but my 1988 v6 camaro has a 5x4.75 bolt pattern. Is there a way I can get around this problem?
Also, what is everyone's opinion on these wheels? Sweet or no go?
Old Jan 16, 2007 | 06:10 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
I'm not sure if it would work, but I'd contact a company like Skulte and see if they can make a spacer that would work in your application. Calling is always worth a try.
Old Jan 16, 2007 | 07:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
5 on 5 is the large GM bolt pattern. Used on pickup trucks, B-body and full size cars. The 5 on 4-3/4" is the more common GM car bolt pattern.
It's not practical to convert your current axles to 5 on 5 but as mentioned above, you may be able to get adapters. Personally, I'd sell the wheels and get some with the proper bolt pattern. Depending on the backspacing, the adapters may push the wheels out too far.
Old Jan 16, 2007 | 10:43 PM
brutalform's Avatar
I think they look good if you own a Jeep, or a SUV. I personally do not think they would look right on a third gen.
Old Jan 17, 2007 | 09:18 AM
Whoodoo's Avatar
But they do look good on a third gen. Disregard the aero kit on this one. (japanese just cant stand to have anything stock)
Old Jan 18, 2007 | 11:11 PM
voodoo427's Avatar
Transmission: th350
they sell those wheels in a 5 on 4 3/4 bolt pattern we used em on our modified.
Old Jan 19, 2007 | 12:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Aero kit? Looks like ground effects from a 91 or 92. It's when they put those stupid big wings on the back that they look bad.
Old Jan 19, 2007 | 09:27 AM
Whoodoo's Avatar
The gfx do look similar to the stock 91-92's, but they were extended a bit and they got some holes put in the front. Im pretty sure its a one-off done in japan somewhere. I personally dont think it looks all that bad, but i just didnt want ppl turning this thread into a "oh my god that body kit is (fill in the blank)"
Where did you buy them, cuz i have only seen 5 on 5 on the 'net.
Old Jan 19, 2007 | 09:46 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
those wheels belong on jeeps who can't afford real wheels and would be much heavier than a nice aluminum rim. Not sure why you'd want a circle track wheel anyways that looks like the cheap off road rims that everyone uses.
Old Jan 19, 2007 | 02:38 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
www.speedwaymotors.com
www.summitracing.com
or any circle track vendor will have them. Just look for something meant for a hobby stock car. You'll need to do some measuring and see what back spacing you need. Stock 16x8 wheels have 5", you'll probably need the same for the 15's, but I'm not sure you can find them with that much back spacing.
Old Jan 20, 2007 | 09:29 AM
Whoodoo's Avatar
From what I have seen, they have a 4.5" backspacing. They are a 9.5" wide wheel. Would they stick out too much?
Old Jan 20, 2007 | 05:11 PM
BMmonteSS's Avatar
Car: 84' Monte
Lets break out our handy dandy calculator....actually for this one I have enough fingers.
Stock 16" wheels are 8" wide with 4" of backspacing in the front and 5" in the rear. So, you have 4" of rim out board of the hub in the front and 3" in the rear. The wheels your looking at have 5" of wheel outboard of the hub 9.5-4.5=5. So go look at your car and see if you have 1" of extra room in the front and 2" in the rear. My experience says it'll look like azz, but your in luck because 90% of these wheels come in 8" width, which would work better.
Old Jan 31, 2007 | 11:17 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
okay im in love with those weld nascar wheels been looking for a little bit now to see if they would work. I wouldnt think the nascar wheels are thaat heavy and for the price i think they just look too good. Do they only come in 15 because the ones on the jap car look way bigger
84z96L31vortec
Aug 20, 2017 12:16 AM
beastin91rs
Oct 9, 2015 07:38 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
