Can I safely run spacers with my WELD draglites?
Old Feb 8, 2007 | 09:21 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I just picked up some 15 x 10 Weld Draglites with 5.5 inch backspacing. While test-fitting them I discovered major interference with the PBR calipers in the rear. I've since ground off the "cooling fins" on the PBR calipers but I'm still making contact with the wheel in a couple of places. I dont want to cut down the caliper any farther. I have some old 5mm spacers that I bought for some minor clearance issues a few years back, and I'm thinkng of using them with the Draglites. It will move the wheel off the caliper and not push it out into the fenderwell lip. Anyone have any experiences like this?
Old Feb 9, 2007 | 12:32 PM
Shagwell's Avatar
Car: projects.......
As long as you still have proper thread engagement, it'll be fine.
- I don't believe weld ever did, but some centerline drag type wheels have a loose insert in the wheel which causes poor balance if it's not siting on the hub center - just something to check.
Old Feb 9, 2007 | 10:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
keep grinding on the calipers, I fit Lt1 brakes and LS1 brakes with 15" welds, so you didn't remove material in all the proper spots then. ls1tech.com has tons of pics to show you were people removed material from the calipers with no ill effects.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
ezobens
Aug 19, 2015 10:29 PM
kah992
Aug 19, 2015 02:55 PM
