doing my suspension
Old Feb 14, 2007 | 10:35 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
doing my suspension
so i took everything down today in the morning.. i went with gr2,s and im expected to get the sportlines tmrw morning from jegs..... this was the first time taking down the hole a arm and spindle..it was easier than i thought... the spindle hasnt came off yet.. i have the bushings which im taking tomorow to get pressed in.. how much would they charge me? i dotn want to get ripped of or something.. because they did it to my friend... im taking my time and i am painting alot of stuff for the detail...along with that i bought the tie rod sleeves form my work and they dont even work with the tie rod ends.. the stock ones where causing major wear on the outside of the rim.. any advice working on tie rod ends?? my old ones (outer ones)look bent.. maybe the way i would jack up the car?? overall the car needed major work on the front end suspension..
btw me and my brother put some one but this was few years ago..i forget which springs are which.. so once they arrive i want to get the car back on its feet..there are skinny one that are thin and thicker ones that are shorter... ???
here are some pictures
Old Feb 15, 2007 | 03:07 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
beefier shorter ones go in the front... and yea dude get some new tie rods and change those endlink bushings.. my pep boys has a set of the polys for $10 so you can keep the hardware (that is if you dont break it taking it apart)
Old Feb 16, 2007 | 01:13 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
yeah im re doing all the bushings..
Old Feb 16, 2007 | 03:18 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
lol im doing the same thing i actually posted right below u. i have my sportline springs and had them for a few months, i was looking into shocks and struts a good performance peice that wont break my budget. i was looking at the KYBs gr2 but they arent to great on the performance side and they are really cheap...they also dont recomend them for cars lowered than 1.5" and our sportline springs will drop our cars 1.6" front and 1.3 rear...u might have drivability problems, or u might bottom out the shock/strut and destroy it. let me know how they turn out and drive and look, im gona be ordering my shocks within the next few days. im thinkin of goin TOKICO blue HP at all 4 corners for 290$ but if ur Gr2's work out good and are only 140$ total thats a better deal.
and replace all the suspension peices, get new tie rods inner and outer etc, new ball joints and poly bushings for sway bar/endlinks and front lower control arms, u might as well upgrade while its out and the differance will be AMAZING trust me.
Old Feb 16, 2007 | 09:35 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
yup.. takin my time painting everythign too.. i heard postive feedback with that combo.. yeah i was on a budget. but.. it should be 10x better than my 200k+++++ original suspension.. lol
Old Feb 16, 2007 | 11:34 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
This was one of the simplest installs I've done. It cost me about $60 to have the old bushings pressed out and the new ones pressed in. You won't even need a spring compressor to get the new springs in since they are so much shorter than the others. I did this whole job by myself in a few hours on my t/a 2 weeks ago. Now I have to do it all over again on the Formula.
Old Feb 17, 2007 | 01:27 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
got the job done today actually i did need a spring compressor.. looks good and rides pretty good .. couldnt beat the price on those shocks..
Old Feb 17, 2007 | 01:04 PM
Demon355's Avatar
Pics?
Old Feb 17, 2007 | 06:53 PM
Car: 87 TA clone
they ride good? they shocks arent too soft for the springs and u havent had any bottoming out problems? i could save alot of $ buy doing your setup, does anyone recomend putting the GR2's on the front and gas-a just in the rear? just to stiffin things up or would that not be good to interchange like that
Old Feb 18, 2007 | 01:54 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i need to do my rear coils... and tie rod ends...
Old Feb 18, 2007 | 01:58 PM
Demon355's Avatar
That looks awesome dude!
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
