700lb free height
Old Mar 20, 2007 | 08:13 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
700lb free height
I have lowered my car and I am not happy with the front end height and ride. I bought the kit 3 years ago so there is no way I can return it. Plus I have used the rears and are fairly happy with the stiffness, just need it a bit higher.
Anyway, what free height would I need with a 700lb spring, and lowered about 1.5'ish inches.(basically the eibach sport front springs)
For the rear, is there a kit similar to the adjustable ground control one thats not so expensive and doesnt come with a set of springs?
Old Mar 20, 2007 | 11:30 AM
HPE's Avatar
HPE
Re: 700lb free height
Hey Jay, How you been. I see you have a new car- Is it that convert you always wanted?
I lost my info on my front springs but if I recall it is on these boards somewhere. I remember them being in the neighborhood of 12.5inches free height. I would access that you would want to try a free height in the range of 14 inches and then trim them down slightly as needed to set the front exactly where you want it AND keeping close to 700lbs- of course the trimming will up the rate slightly, but not much to worry about. Just make sure you have good struts that can damper those higher spring rates as well as have non sloppy valving so it does not bobble on little bumps.
Dean
Old Mar 20, 2007 | 12:04 PM
Dale's Avatar
Engine: 350 S-TPI
I still have all the spring info in safe place
Your rate was 800 though. I may end up going to that.
Convert Ive waited 16 years for, and hunted for 5 months
Old Mar 21, 2007 | 04:11 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Eibach pro-kit front spring (714lbs/in)free height 315mm,which gives 6450mm ride height(measured center of hub to front fender lower lip)
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Oct 5, 2015 06:23 PM
TexasFormula
Sep 30, 2015 06:36 PM
Vincent135
Sep 28, 2015 10:50 PM
