92 z28 rear end argument
I have a 92 z28 305 700r4 and my friend is telling me that they never made a posi drum brake rear for this year nor any other year third gen. Any truth with this? He is tryin to say my 10 bolt rear drum is not stock.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Find your RPO codes and run them. That will tell you what the car came with. Any variation of that, then its been modded.
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
My 92z came with a posi drum rear from the factory, same 305/700R4 as you. But Dale is right, its in the RPO codes.
Cheers,
Richard.
Cheers,
Richard.
Car: 89 Iroc Convertible
My 88 sport coupe has a 10 bolt posi drum rear from the factory.I have the dealer invoice for the car.Look for rpo code G80.Limited Slip rear axle.On mine it was a 100 dollar option
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
Re: 92 z28 rear end argument
my 87 has it i didnt check no codes though, but i got about a dozen black stripes out in front of my house that can verify that i got posi
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
with what Dale said.For what its worth......
RPOs from 1982 -1992
G80 = Rear Axle, limited slip
J65 = Brakes, power front disc and rear disc
If you ordered a car with RPO G80 and did not also get RPO J65 you got rear durm brakes with you limited slip (posi) axle
RPO for 1992 only
G92 = Rear Axle, performance (Z28 coupe only) Included disc brakes all around, but required a 350 engine
Guess you friend is $150. lighter
Dave
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Same here. I have RPO G80 (limited slip) and no J65 (I have rear drums in otherwords).
He owes you $150 and the rest of us a round of drinks!
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
