need help with subframe connectors
Old Mar 24, 2007 | 07:57 PM
Gman_ca's Avatar
hey guys I recently purchased some weld in competition engineering subframe connectors and it just doesnt make sence to me how they weld in at all and of course there are no pictures....well that I can find...if anyone has any info on these could they please help I would like to get these in this week http://store.summitracing.com/partde...5&autoview=sku
there is the link to the ones I have and there is a pdf at the bottom woth the instructions, please help someone lol
cheers
---Garth
Old Feb 25, 2008 | 11:27 PM
tripingeorge3's Avatar
Re: need help with subframe connectors
i'm having the same issue. bought mine last year, just starting install, but the design is retarded. i'm going to use those by my rockers and connect them. aslo just going to make my own subframe connectors
Old Feb 27, 2008 | 10:49 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
OK I am being lazy here but it is late and I only got 4 hours of sleep last night. If you check out the links below you can see some pictures of the SFC I made and how they were installed. Be sure when welding them in the weight of the car is on it's wheels. Otherwise you can weld in a twist to the car and it will be really messed up!
I made my own SFC's because I did some custom work and there are not any SFC that would fit my application.
When I made mine I used tubing that was 1 3/4" DOM. The wall thickness is .134 The mounting plates on the front are 7ga (3/16") mild steel and the rear mount is attached with a two part mount system. The first part was welded in prior to the SFC and is a U shape part that was welded in 360 degrees and form fitted in there. It was about 7" long. Then the rear of the SFC slid up in there and was welded along the sides and bottom. (hard to explain but worked out great and made for a perfect fit!)
I have a air/hyd mandrel bender. So you can do it different but this was how mine were made.
See attached links for pictures and fabrication of the SFC's
https://www.thirdgen.org/forums/su...-wont-fit.html (what SFC's wont fit longtubes?) (what SFC's wont fit longtubes?) (what SFC's wont fit longtubes?) (what SFC's wont fit longtubes?)
https://www.thirdgen.org/forums/ex...html?highlight (My exhaust picture) (My exhaust picture) (My exhaust picture) (My exhaust picture)=
https://www.thirdgen.org/forums/fa...html?highlight (1982 Z28 Silver State project) (1982 Z28 Silver State project) (1982 Z28 Silver State project) (1982 Z28 Silver State project)=
Let me know if you have any questions or send me a PM.
Brett
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
