rack and pinion?
Old Apr 9, 2007 | 07:23 PM
vinceanity92's Avatar
Car: 1992 rs
Engine: 305 tbi
rack and pinion?
has anyone swapped in a rack and pinion? any type of bracketry or p/n's? is it even possible? or have i just not searched far enuf?
Old Apr 17, 2007 | 11:14 PM
myz06's Avatar
Car: 87 IROC
Engine: 406
Transmission: th350
Axle/Gears: 10 bolt 3.73
Re: rack and pinion?
I bought the Flaming river Pinto rack and pinion and ordered all the stuff that I need from BMR (I was getting strut mounts from them also). Got the rack off of Ebay. There's still some fab work that needs done and I'm confused a little. I've searched and haven't found much either on this topic.
Old Apr 20, 2007 | 02:33 PM
Shagwell's Avatar
Car: projects.......
A search for key words rack and pinion will turn up quite a bit. - It's not recommended unless you have extensive fabrication skills and knowledge on proper geometry.
- There is only one rack and pinion available that will maintain a decent turning radius and it is hard to find. Otherwise the spindles must be modified(not an easy task) to bring the tie-rods in closer to the axle centerline. - Without one or the other you end up with the turning radius of a school bus.
Ed1LE
Sep 30, 2018 09:14 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
dimented24x7
Sep 17, 2015 06:58 AM
