Two different ball joints
Old Apr 10, 2007 | 10:57 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
I'm in the process of rebuilding my front end (it's torn apart right now). This morning I had planned on taking my A-arms in to have the joints and bushings swapped when I realized I received two different ball joints in my front end kit (the one from fbodymotorsports). So which one is the right one? Looks like I'll have to order another one on summit (or just order a new matching pair).
Old Apr 10, 2007 | 11:25 AM
Re: Two different ball joints
They both look the same to me, as far as being "right"; just, one of them has the "wear indicator" feature, and one doesn't.
Old Apr 10, 2007 | 02:05 PM
Pocket's Avatar
Car: 91 Trans Am
2nd one looks like the set I swapped out on my bird from Advance auto
Difference looks jsut to be the boot and grease fitting
Old Apr 10, 2007 | 03:07 PM
Grim'91Z's Avatar
Engine: L98 5.7L V8
What if they're different lengths? So they're fine, eh?
Old Apr 10, 2007 | 03:12 PM
Right.
The one that's got the big hole in the bottom is arranged that way so that as it wears, the grease fitting sticks farther and farther out; that way you can just look at it and see when it's used up.
Other than that, they're pretty much the same. The actual "guts" are the same. The only difference is around the sheet-metal plug in the bottom that holds in the grease.
Old Apr 10, 2007 | 03:29 PM
Grim'91Z's Avatar
Engine: L98 5.7L V8
Very well then. Tomorrow I'll have those pressed in and finish up the front. Thanks for saving me from making a pointless purchase.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
