Sphoon A arms Spring fitting question
Old Apr 12, 2007 | 09:15 AM
JamFitz's Avatar
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Transmission: 3.27 auto: stock gear box
Axle/Gears: Stock
Hey all. Got a new K member and A arms installed, offerred up the springs to the spring perches and they were too long by far, so I got the spring compressors on them and still it'll never work.
I was thinking of attaching the ball joint then dropping the A-arms by the rear, then fitting the springs and jacking the A-arm up untill i can reinstall the bolts.
Can anyone tell me if this is how to do it?
Cheers
JAmes
Old Apr 12, 2007 | 11:50 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Sphoon A arms Spring fitting question
Do that and use your spring compressor and it should go together easily. Be sure and index the springs. I also run a chain threw the spring and a-arm and bolt it together. Keeps the spring from flying at you if it decides to pop out.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
redmaroz
Aug 16, 2015 11:40 PM
