Lowering Questions
Old Apr 15, 2007 | 12:41 PM
justins920's Avatar
Lowering Questions
First I'll tell you what wheels/tires I got. I got 225/40/18 up front and 255/35/20 in the back. Right now I have all stock suspension and there's about a 2.5" gap in th front and about 1.5" gap in the back. I would like to even out the gap and have about an inch gap in the front and the back. Any suggestions to even the gap. Thanks.
Old Apr 15, 2007 | 12:53 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: Lowering Questions
I've got 18's up front with P225/40's and 20's in the back with P245/35's. I had the car lowered about 2 inches with the eibach sportlines...and it couldn't look better. The wheels gap is pretty minimal...they tuck really well...almost gives it a "mini tub" look.
Old Apr 15, 2007 | 01:45 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
With that much lowering, I would reccomend some shocks and struts. That will wear out stock/stock replacements in a hurry.
Old Apr 15, 2007 | 03:53 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
For that small of a height adjustment I suggest just trimming your springs a 1/4 coil at a time untill you get the height you want. You are going to be pretty low and need some fairly high rate springs to keep from smacking the bump stops constantly.
This means not using common lower springs as they all have near stock spring rates.
Old Apr 15, 2007 | 08:16 PM
zfreak33's Avatar
just to add to this question, if anyone can help me. if i drop my camaro 1.7" on an 83 z28 with iroc rims, do i have to set the pinion angel. all your input will help. thanks
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
