Best LCA CHOICE?
Old Apr 21, 2007 | 01:22 AM
North's Avatar
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
Best LCA CHOICE?
I am in need of replacing my lower control arms and need an opinion on what to buy. I don't want too expensive but i want quality!!!!
this one is a set that also comes with a panhard bard
http://cgi.ebay.com/ebaymotors/Camar...02326645QQrdZ1
what do you think?
or i could get cheaper generic ones from my dads autobody and supply shop for cost price?
Also, should i be thinking about sub frame connectors?
Old Apr 21, 2007 | 02:42 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Best LCA CHOICE?
That's a very good choice there, UMI brand, sold by UMI, poly/rod end for both. $264 for the set. That's a pretty good price IMHO for what you're getting, but I don't think it's exactly "cheap" for what you may need. Might want to look at lower control arm relocation brackets as well.
And yes, you should be looking at subframe connectors - first actually.
Old Apr 21, 2007 | 11:18 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
UMI products are some of the best made pieces out there, but yes, SFC first
Old Apr 21, 2007 | 03:48 PM
North's Avatar
Transmission: 5spd
ok thanks! I am currently welding in a new floor this weekend and will try to get thew sfc first to weld in with it then get the lcas later
Old Apr 21, 2007 | 05:19 PM
rgauder's Avatar
Car: 1987 Trans Am
http://www.frrax.com/rrforum/index.p...ic=4086&hl=LCA
Old Apr 22, 2007 | 01:42 AM
North's Avatar
Transmission: 5spd
wow i never thought of making my own lcas as im no welder. I am having a guy weld in a new floor so maybe i thought he could make SFCs from scratch, but LCAs are too complicated.
Old Apr 22, 2007 | 02:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
Well, SFC's are usually the complicated ones, but I have Hotchkis ones, and they're EASY. Rectangular tubing, and two flat pieces on the ends to weld to the stock frames. I could make these babies up with a mig welder and an angle grinder in minutes. (very easy).
LCA's again, can be easy or hard, depending on what style. Poly-poly, poly-rod end, or double rod end. Double rod end is probably the easiest, weld in a threaded insert into each end and thread in the rod ends and you're done. A long piece of rectangular tubing and the right size hole saw would make a box style set of poly-poly set, no welding required....
A guy made a post on here a little while ago about aluminum LCA's. No welding required, the parts are fairly pre-assembled. It was a pretty cheap final price tag as well IIRC. He did rubber-rod end.
Lots of ways to skin a cat here.
Old Apr 22, 2007 | 02:44 AM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
http://www.hotpart.com/index.php?p=s...id=3&sub_id=76
When I bought these I found them on ebay through them directly for $99.
Old Apr 22, 2007 | 05:27 PM
rgauder's Avatar
Car: 1987 Trans Am
Read that link I posted again, no welding required.
http://www.lefthanderchassis.com/30.html
Old Apr 22, 2007 | 10:00 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
what do you think?
yeah, you'll want to look at SFCs first.
as far as the LCAs, i went with Spohn non-adjustable ones with poly/poly ends. they work awesome, and weren't expensive at all.
you could also pretty easily (and very inexpensively) get your stock LCAs "boxed", but i don't know if i recommend making your own from scratch.
-brian
Old Apr 23, 2007 | 02:19 PM
rgauder's Avatar
Car: 1987 Trans Am
-brian
Please read the article on frrax.
Old Apr 23, 2007 | 07:07 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i actually read it when it was originally posted. it's a great article, but my suggestion stands - i don't think that making them from scratch is necessarily a good idea for everyone. especially when there are so many that are available out there for pretty good prices.
just my $0.02.
brian
Old Apr 24, 2007 | 04:18 PM
rgauder's Avatar
Car: 1987 Trans Am
just my $0.02.
brian
We can agree to disagree then, part of what makes the world go 'round.
I don't consider screwing a rod end into a pre-threaded aluminum tube of the correct length and having to cut a few spacers really making something from scratch. That goes for someone who might not really be that mechanically inclined.
You are right though, in that it's not for everyone.
Want to "ASSEMBLE" almost the same thing as the UMI brand for less than half the price?---------------> Follow the frrax article
More money than wrenching ability----------------> Buy premade.
My $0.02
Ryan
Old Apr 24, 2007 | 07:21 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
My $0.02
Ryan
well said. together we've got two different opinions and $0.04
brian
Old Apr 24, 2007 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im not a fan of using aluminum pieces for the rear suspension, its probably just me as usual, but id rather have a piece of steel tubing or chromoly than a fatigue prone piece of aluminum holding my rear in my car.
Old Apr 24, 2007 | 08:24 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have the LCAs like the link to FRRAX. I really like them. I had some Spohn dual polyurathane ended ones, and I hated them. So loud and they tended to bind. Here is a link to the thread with them. It may help.
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
Jorlain
Oct 8, 2015 01:57 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
ericjon262
Sep 11, 2015 06:07 PM
