will these tires fit?
Old Apr 22, 2007 | 04:12 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok i have the stock 16 inch rims on my 91 camaro, right now i have 245/50r/16 all the way around. my question is will i be able to put 225/50r/16 on the front and 255/50r/16 on the back?
Old Apr 22, 2007 | 04:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: will these tires fit?
The P245/50R16s on the front is as big as you can go w/o rubbing issues. A few poeple have run P255/50R16s on the front, but in some of these cases they rub. Your best combo is P245/50R16 on the front & P255/50R16s on the rear if your have the 16x8.0 wheels.
The 225/50R16s on the front will be a bit small in OD, but it might work.
Old Apr 22, 2007 | 08:07 PM
BMmonteSS's Avatar
Car: 84' Monte
Axle/Gears: ferd 9" posi 3.50 gears
I've seen 225's on an 8" rim, it isn't pretty, looks like you could peal the tire right of the bead if you cornered too hard.
Old Apr 22, 2007 | 08:29 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Yea, I should have pointed that out also. The proper designed rim width for the P225/50R16 is: 7.0"...... And the 225 is 0.8" smaller in diameter than the 245.
Old Apr 22, 2007 | 11:53 PM
ok so what is the smallest i could go for the front, and widest for the back?
Old Apr 25, 2007 | 12:06 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I would run 245's up front and 275's in the rear.
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Aug 24, 2015 02:53 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
