1LE sway bars?
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
1LE sway bars?
im realizing now someone swapped 1LE front brakes onto my car as well as a 1LE driveshaft, just checked my sway bars and i have 36mm front and 26mm rear, is this a 1LE front swaybar?
Also my car is a 90 iroc, 300 hp 315 ft lbs to the wheels, pro kit springs, lca relocation brakcets and will be ordering lca's soon, as well as an on car adjustable panhard rod.
For all out cornering what do you think would be the most ideal setup swaybars front and rear for my car?
oh its also a 3.73 geared posi 10 bolt if that makes any difference
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
darwinprice
17
Oct 11, 2015 11:51 PM
