biggest tire size i can run?
Old May 9, 2007 | 08:27 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
I have factory 91 formula wheels and i was wondering how wide of a tire can i run on them? i'd like to keep the same height so i don't throw the speedo off. right now i have 235 on there i believe.
Old May 9, 2007 | 08:55 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Re: biggest tire size i can run?
I've got 275/60/15 in the rear of my camaro. fits nice looks good. but i gained 2 inches of tire height. if you can find 275/50/15 you'll have stock height tire. or if your running 16's you can go 275/45/16 and still be at stock height
Old May 10, 2007 | 02:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
255/50-16 is the largest tire you can safely run on a 16x8" wheel. Stock is 245/50-16 (or 235/55-16 on base models). Any wider and you run the risk of bead separation under load.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Vintageracer
Jan 10, 2020 05:33 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
