u joint impacting body pan under high-g's
Old May 14, 2007 | 10:32 AM
suh_wheat_86305's Avatar
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
when i put the pedal all the way down, I heard and feel a thumping. An underside inpection yeilded the observance of fresh scrap marks in the body pan directly above the U-Joint... ugly. The thumping is worse during full throttle while turning. So, I've sworn-off smoking until this situation is remedied. All the underside components look good, u-joints/drive shaft is tight, tranny mount looks in good condition and is feels tight. I did also notice a shiny section on the drive shaft yoke, like it has recently extended. Trans Am, 1986, 305 tpi, 4 wheel disc brakes, auto...
Old May 14, 2007 | 10:39 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Re: u joint impacting body pan under high-g's
is your TQ arm mount OK? is the arm even there? i can't see how the driveshaft could contact the car without being broken and not have the TQ arm broken or missing.
Old May 14, 2007 | 10:41 AM
Replace it anyway. That's the only thing that can cause that.
Old May 14, 2007 | 02:45 PM
Car: 1986 Trans Am
xplane... torque arm is still there... seems in good condition. It seems like a bad idea to have the torque arm attachment point so near the u-joint... sofakingdom, thanks! what do you think about mounting the torque arm basically on top of the u-joint?
Old May 14, 2007 | 09:38 PM
Well millions of these cars have gone hundreds of thousands of miles each, with it mounted just like that; so I doubt that has anything to do with your problem.
It needs a trans mount, no matter what it "looks" like. Just change it out. That's what it always is. Do a search on this forum for "clunk" and "accelerate" or any other combination of words like that, just see for yourself how redundant and repetitive this question really is. It fixes everybody else's cars, it'll fix yours too.
Old May 14, 2007 | 10:01 PM
Tidbit's Avatar
Dude, if you are like pulling over 0.5 g's then your rubber bushings are probably flexing under all that torque from your 305.
redmaroz
Apr 25, 2017 07:14 AM
downsouthboy
Aug 29, 2015 11:29 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
zayne0
Aug 24, 2015 07:22 PM
MENINBLK
Aug 5, 2015 11:58 PM
