Worried about Wheel selection
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
I'd really hate to order the wrong size wheel, and despite reading the sticky i still have no idea which rim to get.
I have a factory drive line on my camaro, factory brake sizes and what not.
I am trying to order a pair of Cragar S/S rims for the front of my car so that they will match the rear. I have no idea what backspacing to pick and all that.
The rims on the rear are 5 lug 15x8. I'm not sure about the back spacing because i don't have the ability to pull them off right now. They do look like dish rims and hang out from the fender slightly.
The pics I have attached hopefully help. These are of the rear rims that are currently on my camaro.
P.S. - sorry for the glare
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Worried about Wheel selection
what size and width are you looking for?
with all the different sizes available its hard to tell what you have from a couple of hazey pics, i would guess the rears are 10" wide so they SHOULD have 5.5 backspacing. 10's in the front are too wide. if it helps i have 8" wheels in the front with 4.5" bs and they are fine.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
If you want to go with an 8" rim all around then you should look at a 4.5" bs. If you want 10" on the rear, then a 5.5" bs. If you want 7" on the front, then go with a 3.5" bs. These measurements should work fine for you
Engine: 5.0l TBI
Thanks guys, actually the rims on the rear are 15x8, I plan on going 8in. wide all around. Thank you for the info!
Car: 86 Trans Am
FYI by the way the pictures look, if the rear wheels are 8", they have a smaller, maybe 3.5 backspace, and they stick out further because if this.
Engine: 5.0l TBI
Oh, I see. I wasn't really quite sure what back spacing actually was. Thanks for pointing that out!
The only 15x8 cragar S/S's I can find have a back spacing of 4 1/4in. Is this ok for the front?
