will these wheels fit?
Guest
Posts: n/a
15x3.5 front pro - stars
15x10 rear pro stars w/ 5.5 backspacing..
im a bit conerned as far as what offset i need... as far as i can tell... backspacing and offset are.. basically interchangeable... until you get into the negative offset range....
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: will these wheels fit?
yes they will fit, might need some pounding on the inner wheel well for the rears, but that would be on a case by case basis with what tire size was used.
Guest
Posts: n/a
well i was anticipating that but my real question is about the offset, i mean.. as far as i can tell as long as the offset is positive , and it has 5.5" of backspacing, it will fit... if the offset goes negative, it will look wider basically... deep dish...
in an ideal situation i want 0 offset correct? because im pretty sure the 4th gens use like.. 38 or -38 mm offset...
thanks for the response btw.
i found a guy local who has a set of pro-stars, 15x10 w/ slicks, and 15x3.5 with skinny's for 500.
i kinda thought it was a st- i mean deal..
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
lets just put it this way.. 15x10 prostars with 5.5" backspacing ARE 0 offset.. 15x10 specs are at the bottom of the page
http://www.weldracing.com/wheels/det...loy%20Polished
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
