For those with spohn subframe connectors
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I was looking at a ordering a set of these but I had a question about them. When looking at an installed pic on their website:
http://www.spohn.net/images/PassSide11.jpg
It appears that the subframe connector goes over the LCA bolt. I wouldnt want to grind the subframe connector out if I needed to change the LCA bushing or something. Would you just weld the LCA nut on that side and then just run the bolt threw from the other side?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: For those with spohn subframe connectors
it has a hole in the plate for you to put the bolt through. the bolt is easily removed and is not covered by the SFC in any way
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Anyone else have trouble removing the LCA bolt from the car?!?! What were your soultions?
darwinprice
17
Oct 11, 2015 11:51 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
The subframe connector bolts up using the lca bolt.
