Need some quick help answer today
Old May 31, 2007 | 12:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
I got a replacement torque arm bushing with the bracket from the dealership. I have all of the nuts and bolts off and have detached the other half of the bushing. Right now the bracket won't come out because of the bottom bolt is part of the bracket. I can't get it out far enough to pull out because it is hitting the tunnel. Is there a way to get it out and put the new bracket in with the bushing without dropping the transmission. This has been alot harder and taken alot more time than I planned. I figured that I may be able to just cut the old bolt to drop the bracket and somehow slide the new one in. Any help is be very much appreciated.
Old May 31, 2007 | 01:31 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: Need some quick help answer today
I had to drop the trans mount and get it from there. It's pretty easy. Take out 4 bolts lower trans w/ jack, while the jack is supporting the trans, take off the old bracket and replace. Once the new bracket is in, jack up the trans (it should line right back up) and install the torque arm. Be sure to use some of the grease that comes with the bushing.
Good luck.
Zach
Old May 31, 2007 | 01:34 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
How far down can I safely drop the trans down. I tried that and was going farther than I felt comfortable with. I dropped it down about 3-4 inches.
Old May 31, 2007 | 01:37 PM
Car: 91 Firebird
Engine: Turbo 355
As far as you need to. Lower it as far as it will go, maybe take your cap off your distributer so it will clear, then jack it up a little ways, this should be plenty of room for you to get the job done.
Old May 31, 2007 | 03:55 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I got it all back together finally. Now the only thing that I wonder about is when I put the car back down I heard a loud clunk from the rear.
Bubbajones_ya
Jul 6, 2024 08:32 PM
J-money
Jan 4, 2019 09:45 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
tgp1990
Sep 4, 2015 06:24 AM
