Moog 5665 Users
Old Jun 17, 2007 | 08:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Moog 5665 Users
After more than a month with the 5665's, the butt of my IROC is still sitting high (higher than I want to live with). The springs are seated correctly in the isolators. I've seen little or no settling. Apparently, replacing the isolator with radiator hose will drop the ride height a 1/2 inch or so. However, I'd still require another 1/2 to get the butt to factory ride height. Will cutting a 1/4 coil get me there? Comments or suggestions are appreciated.
JamesC
Old Jun 21, 2007 | 10:57 AM
JamesC's Avatar
Re: Moog 5665 Users
To update. I replaced the stock isolator with radiator hose, which dropped the ride height 3/8 of inch to 28 1/4.
JamesC
Old Jun 22, 2007 | 07:04 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: Moog 5665 Users
Really that's all with that change?
Old Jun 22, 2007 | 08:34 PM
JamesC's Avatar
Re: Moog 5665 Users
That's all.
JamesC
Old Jun 23, 2007 | 02:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Moog 5665 Users
You still want to get another 5/8" left then?
I guess you can measure your springs, and see how much to cut to get 5/8" more drop. A quarter coil from the top is a good start. Since it's the rears, it's SO EASY to remove and redo it if you want more.
oh right, the 5665's are not the progressive rate, they're the straight rate eh? Ok, cool, chopping progressive rate springs is something I like to think twice about, since you're messing with the spring characteristics more...
Old Jun 25, 2007 | 11:10 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Re: Moog 5665 Users
Don't forget that cutting the coils will stiffen the spring. Think of a coil spring like a long torsion bar. When it's compressed, you're twisting the bar. Cutting a coil shortens the bar, stiffening it.
http://www.efunda.com/DesignStandard...ing_design.cfm if you're interested.
If you cut half a coil off, going to 3.5 from 4 active coils (just guessing the number, haven't looked), that's 14% stiffer.
Deflection = (8*Force*CoilDia^3*number of active coils)/(material shear modulus * wire dia ^4)
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
87v6Bird
Jul 1, 2018 04:12 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
