Widest Tires On Front?
Car: 1991 Camaro RS
Engine: 305 TBI
What is the largest tire that someone is running on the front with a 17"x9.5" rim without any rubbing?
Re: Widest Tires On Front?
Before any one gets in here and tells you to use the search, I think I can answer your question.
With a two inch spacer and 56mm back spacing, 275/40/17 will go up front no problem.
285 requires a little bit of pounding and changing the inside of your wheel well.
Dont quote me on all that, cuzz I am not sure.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have 275/40/17 on 17x 9.5 ZR1s
Dialed_In
Aug 20, 2015 01:45 PM
