Torque Arm Bushing Help!!
Old Jun 19, 2007 | 09:10 PM
89blues's Avatar
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
God my hands hurt from trying to press the outer bracket over the poly bushing in order to start bolts into the bracket.
The upper 13 mm bolt is off center of the hole and the outer bracket needs to move down a a few millimeters to flush with the inner bracket. I don't have the strength to pull this down over the hole.
Any tips? Should I loosen the two long bolts to perhaps give me some play?
Channel locks do not work.
Thanks for help guys
Old Jun 19, 2007 | 11:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Torque Arm Bushing Help!!
I used a C-clamp. Yea, it's almost impossible to compress it with one hand while trying to get the bolt starte, unless you're popeye.
I think I also used an exacto to carve a way a bit of the bushing. One part of the lip is in the wrong place (and yes i'm using the right bushing for an '82 car), so some material can be sliced off for a better fit.
Old Jun 20, 2007 | 12:41 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hmm weird i never have this problem they always go right together real easily for me
i dont understand it
got a pic ?
good luck
Old Jun 20, 2007 | 08:59 AM
89blues's Avatar
Car: 1989 IROC
Yeah that is what I was thinking too. Thanks for the info, I'll shoot a pic of my issue if it still persists.
Old Jun 20, 2007 | 03:11 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
I ran into the same problem. I had a ffreind with me as we did the rear control arms and panhard rod at the same time. Replacing the busking took longer than doing the rest of it. We both pryed on it and attempted to take it out and bend it with a vice from what I remember(this was 5 years ago). Another hand will definitely help. Sorry i don't have more detailed instructions for you.
Old Jul 9, 2007 | 01:45 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
I Just did this project using the one spohn sells. I used a small c clamp due to working area tight and a small hammer to tap the holes back in line. The bushing was getting the best of me for a while but just take your time. Not the funest places to work on.
Nervous2
Oct 8, 2015 10:53 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
