Sway bar bushings
Old Jun 26, 2007 | 07:21 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
Sway bar bushings
Ok i was told both of my end sway bar bushings are gone and that i need new ones, ive looked but there are many diff sizes, what do i need?
Car is an 85 trans am with the factory "performance suspension"
Old Jun 26, 2007 | 08:42 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Re: Sway bar bushings
You need to measure the swaybar. As you have already found there were many factory options for the swaybar. One way to check is to use an adjustable wrench. Tighten the wrench onto the bar, slip it off and measure the spread of the wrench flats.
Old Jun 26, 2007 | 09:06 PM
Celticsfan's Avatar
Car: 1985 Trans Am
there wasnt one single size for the trans am in 85?? Well itll be a while til i get it back on a lift...damn shoulda measured it then
Old Jun 26, 2007 | 10:10 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
this may help some
https://www.thirdgen.org/forums/faq-...-sway-bar.html
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
