Comfortable ride with lowering springs?
Old Jun 27, 2007 | 01:52 AM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
OK. I am looking for a set of lowering springs for my 89 RS convertible. Want to drop it 1 inch all the way around to make it look good with the 18x10's. But I want to keep the nice comfortable ride. This is my daily driver/cruiser. I have my IROC for the fun stuff. I would like to do air bags. But no money for that right now. One of my friends told me to cut one coil off of each spring. But I don't know about that. I would rather find a set that has what I want. So what are my options.? Adam :-)
Old Jun 27, 2007 | 01:53 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Comfortable ride with lowering springs?
The ride from my Eibach springs is not too bad. Cant compare the ride to stock as they were on the car when i got it. As I understand,ALL,lowering springs will be of a higher rate than stock to compensate for the drop and keep the car from bottoming out. Cutting the stock spring WILL increase its rate also, however, i dont know if it will be as stiff as an aftermarket drop spring, all that math is above my want to know.
Old Jul 3, 2007 | 12:05 AM
Got me a set of Hotchkis Sport Coil Springs. They lower the car one inch. Which is what I wanted. Plus I looked at the spring rates. And they are actually a little softer then my 87 IROC factory springs. So it shouldn't be that harsh. Now I just need to find the right strut/shock setup to go with that spring choice. Adam :-)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
