265/35/18 or 275/35/18
I have four 18x9.5" rims and trying to decide what tires to get. I don't have a lot of cash to spend. I know most people run 275 on a 9.5" rim, but seen a 265 run on the front. How would running 265 on all four corners be? One reason is because I can get 265's quite a bit cheaper...also I dont like the look of thick tires all around, but want to keep all 4 the same for tire rotation (and I have a V6).
And using a tire size calculator I see a 265/35/18 will be a little smaller diameter so the speedo will be 1mph off, but will this affect gas mileage much? Not too concerned with ride smoothness because I will sacrifice that if I need to, my car isn't driven that much.
Matt
Matt
