Quick tire question
Car: 91 Trans Am
Quick tire question
Search is down
GTA wheels 16x8
I know 255/50/16 will fit because I have them in the rear
How will the fronts be affected?
Concerning turning and rubbing and common stuff
GTA wheels 16x8
Car: 89 TransAm
Engine: 305TPI
Re: Quick tire question
I run 255 50's all the way around mine. 89 T/A 305TPI
Scrubs in the front in sharp turns...otherwise no problem.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
On some or most 3rd gen cars, the 255/50R16 will rib while on the front positions at full lock. I would put 245/50R16s on the front and the 255s on the rear. This will give your car a bit of rake.
Car: 91 Trans Am
I have 245's up front and 255's rear
I can get a set of 4 255's pretty cheap or a set of 4 245's
Looks like im goin back with the 245's
