Moog suspension parts
Old Jul 7, 2007 | 02:04 AM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
Are moog suspension parts polyurethane or not? I have heard about them both ways. Dont most of O'reilly and napa carry moog parts?
If they are poly urethane i think ill just buy them instead of ordering energys kit mainly because i can go up to napa anytime I need a part.
Old Jul 7, 2007 | 04:39 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Re: Moog suspension parts
I don't have an answer to your question; however, I'm about to start looking for a good front rebuild kit that is Moog specific. All the suspension shops I've talked to so far say that Moog has the best and most respected front end parts, plus they have greasable bushings....
Have you found a good source for the Moog parts yet? Nitro
Old Jul 8, 2007 | 12:02 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Moog parts are generally stocked at any and all auto parts stores. They're the factory replacement part. It's not (usually) cheap off shore Chinese stuff, from everything i've seen it's solid American made stuff, and it's pretty high quality. It's stock though, don't expect miracles.
And no, it should be rubber, unless you specify a poly part. I do think MOOG makes some poly bushings now.
Old Jul 8, 2007 | 01:42 AM
fastcar06's Avatar
Car: 1991 pro street formula
Engine: 355
Transmission: turbo 350 w/ 3200 stall
Axle/Gears: 9" ford detroit locker w/ 456
last time i checked napa carries a private label as does auto zone. carquest, federated, and parts plus have the moog line. their is no o.e. equivilent to moog in my opinion. moog uses oe materials in their products but i do beleive they have some poly sway bar links and bushings.
Old Jul 8, 2007 | 05:56 PM
neagan's Avatar
What manufacturer of front suspension parts other than Moog would you recommend? (I'm scheduled to replace my entire front suspension this month and want super high quality/durability) Nitro
Old Jul 8, 2007 | 06:34 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
It seems like the cheapest place i can find Moog parts is Rockauto.com i priced out a compelte front end rebuild kit and it came to $325 whereas Spohn is asking $400 for the EXACT same parts.
Old Jul 8, 2007 | 09:30 PM
855speed's Avatar
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
TRW makes parts. You can get them at Advance. Had good luck with their stuff.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
