Anyone use these LCAS?
Car: 1989 GTA
Axle/Gears: 3.23s
http://www.jegs.com/webapp/wcs/store...95134_-1_10063
I found a parts car and the owner is selling the same type for $90. They seem rather cheap since I've seen new LCAs go for around $220. This guy said he got his for $145 from Jegs.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Anyone use these LCAS?
the link does not work, so i cant help there, but you can get the lakewood control arms from summit/jegs for around 94 bux new, plus shipping of course. or you could dig around ebay and see whats there, usually you can find good part for a good price there.
Car: 1989 GTA
Axle/Gears: 3.23s
Car: 86 Trans Am
thats a lot of money for a set of boxed arms, the lakewood ones are the same thing and cost almost 100$ less, but if they are in good shape and you can get them cheaper then go for it.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i got mine from spohn for ~115 new.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Granatelli makes pretty good stuff. sure they're compairable to UMI, Spohn, BMR, etc. also they are tubular not boxed
Hello,
Here is another option- www.umiperformance.com/2015
If you have any questions please ask.
Thank you!
Ryan
Thank you!
Ryan
Boxed = crap
Those Granatelli ones aren't boxed, they're square tubing.
Tubing, either square or round, is the way to go.
I have the Lakewoods. http://go.mrgasket.com/pdf/tractionbars.pdf page 3 of the file, part # 20140. Cost me about $75 at the time (which was not real recent....) They look IDENTICAL to those Granatellis except they're black instead of red. I fail to see what you would get by paying twice as much for the Granatelli product.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
"boxed" technically means you welded some flat bar into your stock ones and "boxed" them. That's what i've done, pretty cheap, and you approach the strength of a square tube version (approach is the key word).
UMI himself posted a link to his version there, $105 with grease points on it - that's a good piece there.
Car: 1982 Trans-Am
GROVER! You've gotta tell me where you got that avatar of Bucky, and if there are more like it out there.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i like my BMR LCA's.. i have this one... adjustable with no need to take them off for adjustments
http://www.bmrfabrication.com/contro...able-large.jpg
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Car: 1989 GTA
Axle/Gears: 3.23s
Boxed = crap
Car: 1982 Trans-Am
One is round, the other is square....
Round is a bit smaller, more clearance for massive tires. There isn't really a structural difference until you hit thousands of HP most likely.
Car: 86 Trans Am
i heard somewhere that the square tubing stresses more unevenly because of the square shape with 4 corners, as opposed to the round, where the stress is evenly distributed around the circular shape.
could be total
im not an engineer
could be total
im not an engineer Supreme Member
Car: 1984 Trans Am
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
