Spohn Control Arm Help
Old Jul 6, 2007 | 05:52 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I have a set of rod ended control arms on the rear of my car. Theres rod ends on both ends. Im having a problem with play in the bolts. The rod end seems to have a wider hole than the bolt which goes thru it. I can move the rear front to back. Do I need new bolts to go with these arms? I didnt get any when I bought them. What do you guys think could be up.
matt
Old Jul 6, 2007 | 06:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn Control Arm Help
the issue is probably that, while the stock bolts on the car are 12mm, the bolt holes in the arms are probably 1/2" if this is the case, and you want to continue with them, you can drill out the mounting holes to 1/2". or see if you can get the right size spacers
Old Jul 6, 2007 | 09:22 PM
Drilling out the holes is what I was thinking. Im just wondering if anyone else here has had the same problem.
Matt
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
