slicks up front
Old Jul 17, 2007 | 07:29 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
slicks up front
isnt there a chart that shows what tire sizes can be ran front and rear?
ive been searching for hours and cant seem to find it. all i want to know is if a 26.5 x 8 - 15 will fit up front if anyone knows i would be very thankful...tao
Old Jul 17, 2007 | 07:41 PM
Stephen's Avatar
Car: 87 GTA
Re: slicks up front
The stock 245/50R16, is about a 26" diameter, 10" section width/8.5" tread width tire, so that should fit fine, even if the car is dropped an inch.
You thinking autox slicks? Drag slicks would be horrible for handling, especially on the fronts, with the turning forces on them.
Old Jul 17, 2007 | 07:43 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: slicks up front
guess i should have said they are for autox my bad thanks for the info...tao
Old Jul 18, 2007 | 12:20 AM
Stephen's Avatar
Car: 87 GTA
Re: slicks up front
If you have a local autocross club, check around, or look up grassroot motorsports. You should easily be able to find a 3rd gen running autocross, to check out.
26.5" tire....That's SHORT!
Old Jul 19, 2007 | 04:38 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Re: slicks up front
Are you sure that a slick is allowed? In SCCA you can only use a slick in C Prepared class. The other classes are using DOT approved tires. The common stock class tire is a 265 45 16 Kumho V710 which is 25.2". I would look for a set of 16" wheels if I were you.
just saw that you have a 406 engine so you are in a class that will allow a slick but bigger is always better an stock 16x8 wheels aren't that expensive to buy. They don't need to be pretty after all.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Beeman
Aug 31, 2015 07:40 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
