z06 wheels?
Old Jul 30, 2007 | 07:16 AM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
z06 wheels?
ive got a set of z06 wheels and tires, front are 275 on 17's rear are 295's on 18's, my question is what size wheel adapters should i run on the front and rear? i want to keep the wheels in the fender wells, ive got an 86 base firebird, and im running a swapped in 9 bolt with disc brakes.
Old Jul 30, 2007 | 09:17 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: z06 wheels?
We need to know the offset of the wheels in order to tell you the correct sized spacers.
Old Jul 30, 2007 | 10:23 AM
Re: z06 wheels?
If they are REAL FACTORY Z06 wheels, then you need 2" all the way around.
If they're aftermarket knock-off look-alikes that merely resemble Z06 wheels stylistically, then who knows. All bets are off since anybody can cast wheels that look like anything, and make the offset anything they feel like, within the physical possibilities allowed by whatever they "look" like; and they usually do. As said, you need the measurements FOR YOUR PARTICULAR WHEELS in that case, in order to know.
Old Jul 30, 2007 | 10:27 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: z06 wheels?
2 1/4" for the fronts, 2" for the rears.
You need the extra 1/4" on the fronts for the tie rods. OEM ones are a little different than my MOOG ones.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
