little help
Old Aug 4, 2007 | 09:38 PM
stoned_pimp420's Avatar
Car: 1990 Buick Century (pimped out
Engine: 3300
Transmission: 4 spd auto
Axle/Gears: ??????????
little help
A buddy that I'm gonna leave unnamed (due to site reference) gave me a f41 front sway bar, I was wondering if I'll see any improvement over FE1 front sway bar as far as handling goes or would it be a waste of time it buy poly bushings and mount F41 on my FE1 Rally sport
Old Aug 5, 2007 | 06:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: little help
IIRC, the F41 is a 34mm bar, the FE1 a hollow 36mm. If you're currently running the 36/24 combo, I'd stick with it.
JamesC
Old Aug 5, 2007 | 07:55 AM
Engine: 3300
Re: little help
so fe1 isn't all bad just worn out I guess
Old Aug 5, 2007 | 08:22 AM
JamesC's Avatar
Re: little help
My bad. The FE2 is the 36/24 combo. Check the following link for more info:
https://www.thirdgen.org/forums/faq-...-sway-bar.html
JamesC
Old Aug 5, 2007 | 09:20 AM
Engine: 3300
Re: little help
so it couldn't hurt to use the f41 swaybar and replace the factory rubber bushings to poly
Old Aug 5, 2007 | 09:42 AM
JamesC's Avatar
Re: little help
No, couldn't hurt.
JamesC
