UMI has a arms now, what do you guys think?
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Different design from the Spohn and BMR a arms. Anybody see a reason not to use these?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: UMI has a arms now, what do you guys think?
look good to me
, i bought a set.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm not seeing a stop in the spring pocket like the OEs, otherwise they look good. What's the price tag and do they lower like the Spohns?
Car: 82z28
Engine: 406
Transmission: th350
Do explain the benefits other than bling. What the difference in weight between these and the stockers? Personally I'm going with braced stock arms and global west bushings
I asked about indexing the springs, here is he response I got:
Just eye-ball it close to factory. The spring can sit pretty much any where you want it to. Once the weight of the vehicle comes down the spring sits flat. It doesn't matter where it sits, we just line it up where the stock spring sat from factory on all our installs.
Hope that helps,
Ryan
Hope that helps,
Ryan
Car: 90 Formula
Car: '87 FIREGOOSE!!!!
First, I have to say I am a total backer of UMI performance, Ryan and the guys are great, and do great work.
But, I do second the question, other than a bit of weight savings, what is the biggest benefit? Looks????? More room????? Please give info.
I do really like these pieces, but what are the benefits to justify spending the cash.
I was also told that the Torque Arm is now availible for our cars, the one that relocates it off the transmission.
I wonder how long before they release a K-Member for 3rd gens??? Hmmm.
I take it they sent you this info by e-mail? They aren't on their website. They told me of the release of the new torque arm, it'll be up on their website soon too I was told.
I have their TQ arm already, it comes with a new transmission cross member, were the tq arm mounts, a real nice piece. Click on the links in my sig for pics.
Ryan doesn't think there will be any issues with sportlines, but he hasn't tried the installation with them yet.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I'm also a BIG fan of UMI and so far all my suspension is UMI.
I wrote to Ryan about purchasing a set of A arms and if they will be making a K member anytime soon (like BMR and Spohn). He said they are working on it. Also their A arms fit like the factory ones so a Spohn or BMR k member should fit.
Don't hold your breath on sway bars though. He said they have no plans to make sway bars and that neither Spohn or BMR make their own sway bars. They are made by a third company.
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Wow, I'm gonna have to look into getting a set of them there beauties, even if just for looks..lol. They gotta be stronger than the stock crap.
Thanks for the comments
The A-Arms weigh in at 5.56lbs less per set then the factory A-Arms. Not a huge savings but every pound helps. I must admit this was one tough A-Arm to build with reduced weight with out sacraficing strenght.
I have currently put over 3,000 miles on a set with absolutely no issues. I actually drove them on a vehicle all last fall and winter.
Other benefits of this item are new MOOG ball joints and polyurethane bushings.
If anyone has any questions please ask. Thank you!
Ryan
Ryan
Car: 90 Formula
Hope that helps,
Ryan
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I think it's interesting that the a arm curves down and the spring pocket it level with it. I have the spohn a arms and there spring perch is lowered in the middle.
Car: 86 Trans Am
Engine: 406 Roller
I talked to spohn about his a arms. He said the first design lowered the car. He said I have the updated perches so hopefully this isnt a problem. The UMI pieces look nice.
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
when im done with the rear suspention im getting a set of these guys
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
