tire size
Old Aug 20, 2007 | 05:34 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
tire size
I have the 16" iroc wheels on my car. Currently in the front I have a 3 inch gap between the top of the tire and the fender lip. In the rear there is about a 5 inch gap between the top of the tire and the fender lip. Right now I run 245/50ZR16 on all 4 corners. If I put a pair or 245/50 in the front and a pair of 255/50 on the rear will it close up the gap between the top of the tire and the fender lip in the rear. What im trying to is fill in the wheel well in the rear a little more. So will going from a 245 to a 255 close it up a bit more??
Old Aug 21, 2007 | 09:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: tire size
Very marginally.
Springs would be a much better closer.
Old Aug 21, 2007 | 09:49 AM
Stephen's Avatar
Car: 87 GTA
Re: tire size
Why you have 3" & 5", is a better question.
Even brand new, they wouldn't sit that high. Has the car been driven, since installation? Sometimes shocks, will hold the car up higher, if they haven't been cycled. Either by being driven on, or at least "bouncing" the car manually, to cycle the shocks.
Old Aug 22, 2007 | 01:11 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Re: tire size
well i havent put them on yet. its still stock. im approximating the 3 and 5 inch. I just wanna bring the rear down a bit lower to match the front so it sits level. I figured with 255 in the rear and 245 in the front it would bring that margin closer together.
Old Aug 26, 2007 | 03:55 PM
speshulldroo's Avatar
Car: 1984 T/A
Engine: L69
Re: tire size
tire size is probably not the best way to do that, as if you're going to run two different sized tires, you usually want the back tire taller anyway. the thing that affects ride height the most is springs, and then shocks.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
