a few?'s about upgrading suspension
Old Aug 22, 2007 | 08:48 PM
dalunchbox18's Avatar
i'm building a 91 rs, its gonna be in the range of 425-450 hp, with like 450 tq, but not a drag car, more of a street/scca car, people say its too much for racing scca, but i dont give a shyt, i'm building that power to beat on ricers around here,anyways
my ?'s are:
-what are the best/stiffest sub-frame connectors around for the money??
-will a 4th gen rear bolt right up in my 91??
-if not, what fabs will i have to make?
-will i have to change the driveshaft, while using a t5 tranny?
-what are good 2" lowering springs for camaro, are 3rd gen and 4th gen rear lowering springs the same?
-is it worth it changing out the stock rear?(3.08, limited-slip,drum brakes)
-any other suspension parts that are actually worth buying?
sorry for all the questions, just wanna make a badass 3rd gen the right way, and when i'm done i will deff make sure to give you people your credit, for all the info you've given me, thanks
lunchboxxx
Old Sep 1, 2007 | 02:08 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: a few?'s about upgrading suspension
I personally like Spohns SFCs, they are tubular and easy to weld in. Make sure not to get bolt in SFCs Alsons are also very good.
Yes a 4th gen rear will bolt right up to a 91... but the only true advantage is having it wider. You would be walking on thin ice with beating on a 10 bolt like that. I am personally running a built 10 bolt. But if i were to spend all the money that I put into that rear i would just buy a 9" or 12 bolt.
You will need new wheels.
No, the driveshafts are all the same length. May I suggest using a 4th gen aluminum balenced d.s?
The rear springs are the same but the fronts are not from what I have read. I am using the Eibach Sportlines I love how these handle but there are many discussions on which are the best.
It is worth it if you plan on going big. 4th gen rears are not much stronger then the 3rd gen...
Other needs are Lower control arm relocation brackets. A wonder bar. Larger Sway bars, Lower Control arms (LCA) Aftermarket. New shocks are also a suggestion of mine...
Goodluck,
Dennis
J-money
Jan 4, 2019 09:45 AM
Veaceonee
Sep 29, 2016 08:15 PM
starfinder
Oct 25, 2015 10:40 AM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
