How to mount Sphon torque arm?
Old Aug 29, 2007 | 01:40 PM
Phoenix1987's Avatar
Car: 1987 Trans Am
Axle/Gears: 4.10's
I have the adjustable Sphon torque arm that mounts to the big *** Sphon t 56 crossmember. I am going to have the crossmember removed, as I have long tubes and the ground clearence is crap, and I am wondering how I can keep the adjustable torque arm. How can I mount it? Is there a way to make a bar that connects to sub frame connectors that I can connect to the torque arm mount?
Old Aug 29, 2007 | 01:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to mount Sphon torque arm?
I've got my dual exhaust turning down, out and around the "old" Spohn crossmember that was even more in the way, with about the same ground clearance that would be had going under a stock crossmember.
Old Aug 29, 2007 | 01:47 PM
AC's Avatar
AC
Car: Used to drive a camaro
Apeiron, you have pix of that setup?
Old Aug 29, 2007 | 04:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really, but others have posted similar pics before. I'll try to find one later tonight.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
