wonderbar and stb?
Old Sep 5, 2007 | 10:31 PM
racerx520's Avatar
wonderbar and stb?
how hard is it to mount a wonderbar and stb?, with the stb's, do you just find a good spot and bolt it on? or what...ive been looking on the web to try to figure it out and i cant quite figure itout lol
Old Sep 6, 2007 | 12:34 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: wonderbar and stb?
STBs usually have a template and require drilling into the upper strut mount area...which is triple thick steel. The WonderBar is easy. Drop the sway bar mounts up front, and sandwich the WB in. Recomended to do with a load on the wheels since you will want to pre-load the sway bar back in place.
Old Sep 6, 2007 | 11:15 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
i had mine on a four point lift when i put in my wonder bar, but my sway went back up fine, course my bushing are long gone, did i mess something up? just want to knw what the deal with pre loading is as i've seen it before and don't want to run into complications on future installs
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
james_fearn
Aftermarket Product Review
Aug 12, 2001 03:48 AM
