1 inch drop
Old Sep 8, 2007 | 04:20 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
1 inch drop
Im planning on dropping my car 1 inch by getting some moog replacements and cutting them. Will I need the lca relaction brackests and adjustable panhard bar with such a small amount of drop? Thanks in advance.
Old Sep 8, 2007 | 05:22 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: 1 inch drop
Why don't you just buy 1" drop springs? I would recommend the LCA relocation brackets, I get wheel hop going around corners with 1" drop springs. I would have them if I had more power than my V6 makes
Old Sep 8, 2007 | 06:04 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 1 inch drop
NO need to relocate anuthing and buying a set of 1" drop springs is a smarter move.
Old Sep 8, 2007 | 09:08 PM
Camaro5690's Avatar
Re: 1 inch drop
what brand of drop springs do you suggest?
Old Sep 8, 2007 | 09:22 PM
Car: 2012 Corvette
Engine: LS3
Re: 1 inch drop
Eibach has 1" V8 drop springs. I think I have Intrax V6 drop springs and I really like them.
Old Sep 8, 2007 | 09:24 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: 1 inch drop
If you're ONLY doing it for looks (and not doing any kind of performance driving), then you can get away w/ Eibachs - but for any kind of handling, they're a freaking joke. Do your own search here if you want to confirm that.
I've done what you initially suggested - got a set of replacement springs & took half a coil off of them. The disadvantages are that my springs aren't powdercoated some spiffy color, & I didn't get any cool stickers with 'em.
But considering the fact that I spent $60 instead of $200, I've somehow managed to live with it...
Old Sep 8, 2007 | 09:25 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: 1 inch drop
If you use the moogs and cut them correctly, you will get withing a few lbs in spring rate as the Pro-Kit and have very near the same ride height... and have saved about $100. Don't forget new shocks when you lower as well. LCAs and PHB aren't really needed, but LCA relo brackets would be a good idea to return the geometery to where it was designed to be. Not saying that LCAs and PHB aren't a good idea, though.
Old Sep 8, 2007 | 09:32 PM
V8Rumble's Avatar
Re: 1 inch drop
91_5.7_TPI hit it right on the head - IMO, the panhard bar probably isn't needed, at just a 1" drop. The LCA relo brackets aren't strictly necessary, but they're not a bad idea at all.
Old Sep 8, 2007 | 10:05 PM
Camaro5690's Avatar
Re: 1 inch drop
only reason I dont wanna have to do relocation brackets or panhard bar yet is because I am on a limited budget. All I am doing is springs and shocks/struts for the moment. When I get more money I will doo the lca relocations and phb. But Im doing it to replace my completely shot suspension. Its probably sagging more than an inch right now. Anyone got a pic of what the correct OEM ride height looks like? with the 215/65/15s
Old Sep 9, 2007 | 08:06 AM
Car: 2012 Corvette
Engine: LS3
Re: 1 inch drop
Don't take my word for it, but I doubt you will notice a difference without the LCA relocation brackets in normal driving. However, if you do a burn out or if you have a posi and it locks going around a sharp turn, you will probably get wheel hop. My car was sagging about an inch when I put my springs in. I put them in and didn't really notice much of a difference in looks, until I put my new wheels and tires on with the correct tire size that filled the wheel well better (someone put 215/60/15s on the stock wheels).
amargari
Nov 10, 2015 02:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
