Weird squeaky/rattly steering
Old Sep 11, 2007 | 04:50 AM
andy625's Avatar
Car: Firebird 1987
Engine: 5.0
I have an 87 Firebird which has been feeling a bit vauge on the steering for the last couple of months. The last week I have noticed a squeaky sound that seems to be coming from the steering when I pull up next to another car or wall for the sound to bounce off of.
I had a check under the car and all the joints seem to be ok except the main shaft coming through the firewall from the steering wheel into the engine bay. The 12" or so section leading up to the rubber joint near the steering box seems to have a lot of up and down play in it when I grab hold of it and pull it up towards the hood and press down towards the road. I think maybe the joint nearest the firewall is worn.
I think the noise I can hear is either the joint nearest the firewall or the actual rubber disc joint which also seems to have play in it so that when the wheel is turned without the engine running, the section of the joint connected to the steering wheel side of the joint moves independent of the part connected to the steering box. ie you can see the metal parts of the joint getting closer as the wheel is turned.
Are these joints prone to wear on the F-body, and do they normally make a squeaky rattly noise when they are worn? I've read about rag joint eliminators, astro van parts, and flaming river shafts. Whats the best solution?
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
